rangerskm
Full Member level 4
- Joined
- Jan 23, 2013
- Messages
- 199
- Helped
- 0
- Reputation
- 2
- Reaction score
- 0
- Trophy points
- 1,296
- Activity points
- 2,663
actually i am do a mini project and i need some help in it as soon as possible.
mplab ide with hi tech c compiler
1) i need code for the given logic
component using
8 led array, a temperature sensor
pic16f877a
lcd and 4 switch.
i need to design embedded c code by using the above items.
my idea is to read temperature sensor and to display it in the lcd in a running manner ,along with some of the welcome messages in it.temperature has to sensed when the first switch has to be pressed.led has to be glowed brightly and dimly based on temperature .
can any one help me .it will be kind of you,
component using
pic16f877a
lcd and 4 switch.
