help needed for st power line modem
fireplus
Full Member level 3
i have a toko coil (a042) it's frequency at 125khz
but the data sheet tells that you may use T1002N it's fequency at 100khz
can i use a042 or not???
any body have any information on this field please let me know
the resource on the net is very low
if you could help please :oops:
Blackhawk
Maryland, USA!!!!!!
I would go with what the datasheet says.
You said you had a power line modem problem? IS this the big transformer on the board that you are talking about or one of the toroids or other coils?
mtawab74
Member level 3
in ur application the transformer is not involved in any resonance action
i think it's only for isolation
fireplus
Full Member level 3
i don't have the demo board only i have the st modem and toko coil a042 the remaning system i will build it
i don't have any seminar or books in this field
i hope also if any body have any thing in this field please upload
or any helpful links :oops: :oops: :oops:
mtawab74
Member level 3
here's all what i have about P line modem
