E11022
Junior Member level 2
Design and Analysis of a PIC-Based PWM Speed Controller of a DC Motor using a DC-DC buck Converter .
This is the project i need to work on within 2 weeks time. Each of us got a different title.
I am confused now. Input = Buck converter, Output = DC motor
How to actually play with the buck converter to change the speed of controller?i know we need to adjust the voltage supplied to the Switch in Buck converter, so that voltage vary, PWM signal vary and speed of DC motor vary. But,
1) Can i use normal switch like trigger switch for Buck converter or must use MOSFET?
2) How to connect this 3 things together, the Buck converter, PWM signal and DC motor.
Input of switch goes to input of PIC, PWM controller in PIC being set(how to set and set what), output of PIC to DC motor
Please help me!!!
Thanks~
Please help me!!!
Thanks~
use proper titles that describes the content of your message, in the future your posts will deleted if you use meaningless titles [alexan_e]
