Help me with writing a VHDL code
voho
Full Member level 2
Nador City
help in vhdl
Hi all,
How to do this in vhdl ? Event is input signal
event___ ____________ ____________ ____________ _____
|__ | |__| |__| |__|
V1______ _____________________________________________________
|__|
V2______________________ _____________________________________
|__|
V3______________________________________ _____________________
|__|
V4______________________________________________________ _____
|__|
Thank's in advance
Re: help in vhdl
can you just explain what are you trying to do, the diagram drawing is ver unclear ?
help in vhdl
do you want to do what ?
Re: help in vhdl
And what happens after V4?
Do you repeat from the start?
	     |__ |		      |__|		      |__|		      |__|
	      |__|
			                  |__|
					                              |__|
							                                          |__|
help in vhdl
I think that the algorithm is something like that:
For every rising edge of event signal we will have to increment a coutner (0,1,2,3,0,1...). The counter's output is the address input of the demultiplexer. And the input of demultiplexer is the event.
voho, Is it so?
Re: help in vhdl
thank'a all for your help,
I want to do this in first event i generate event (pulse)in V1, second event i generate event inV2, third event i generate event in V3
regards
Re: help in vhdl
it looks like a shifted signal on each rising edge of the clock.
you can use shift register in this case.
Re: help in vhdl
Checkout the code below!
Hope this helps!
library ieee;
use ieee.std_logic_1164.all;
entity sequncer is
  port (
    event : in  std_logic;
    rst   : in  std_logic;
    v1    : out std_logic;
    v2    : out std_logic;
    v3    : out std_logic;
    v4    : out std_logic);
end sequncer;
architecture behave of sequncer is
signal shift_pos : std_logic_vector(3 downto 0);
signal shift_neg : std_logic_vector(3 downto 0);
begin  -- behave
  v1 <= not shift_pos(0) or shift_neg(0);
  v2 <= not shift_pos(1) or shift_neg(1);
  v3 <= not shift_pos(2) or shift_neg(2);
  v4 <= not shift_pos(3) or shift_neg(3);
positve_edge: process (event, rst)
begin  -- process positve-edge
  if rst = '0' then                     -- asynchronous reset (active low)
    shift_pos <= (others => '0')
  elsif event'event and event = '1' then  -- rising clock edge
    shift_pos <= shift_pos(2 downto 0)&shift_pos(3);
  end if;
end process positve_edge;
neg_edge: process (event, rst)
begin  -- process neg_edge
    shift_neg <= (others => '1')
  elsif event'event and event = '0' then  -- rising clock edge
    shift_neg(0) <= shift_neg(2 downto 0)& shift_neg(3);
  end if;
end process neg_edge;
end behave;
