Help me with solving a problem concerning RL with switch
kavitha_rapolu
Junior Member level 3
rl with switch
In the attached figure with rl circuit and switch , at t =0- iL(0-) is 5ma , but why is the current at t =0+ ( ie when the switch is open ) iL(0+)= 0A ? Why is it violating the rule that current across the inductor can't change instantaneously ?
Old Nick
Advanced Member level 1
Re: rl with switch
You'll want to check out the voltage accross the inductor when you flip the switch!!
kavitha_rapolu
Re: rl with switch
isn't the voltage across the inductor 0 in both the cases (ie when the switch is first closed and then open) ?
But why is the current at t=0+ 0A ?
