May 27, 2004 #1 J jgx Member level 1 Joined May 21, 2004 Messages 33 Helped 0 Reputation 2 Reaction score 0 Trophy points 1,286 Location brazil Activity points 210 code hi how I can simulate I beginning !!! and
May 29, 2004 #2 C clivechen Member level 3 Joined May 29, 2004 Messages 65 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,288 Activity points 500 code composer 2000 if you only want to simulate your dsp, you can 1 choose ccs setup 2 import the simulator of your dsp 3 reset and your ccs 4 reset the CPU 5 load program 6 run that is ok
May 31, 2004 #3 J jgx Member level 1 Joined May 21, 2004 Messages 33 Helped 0 Reputation 2 Reaction score 0 Trophy points 1,286 Location brazil Activity points 210 Re: code composer 2000 hi I have a problem in the simulator show this message: Trouble Writing Target DSP Memory Error number -2052 Error Address 44 Memory Map Error:Range How I can simulate???? or you know some information about it's. Thanks!!!
May 31, 2004 #4 C clivechen Member level 3 Joined May 29, 2004 Messages 65 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,288 Activity points 500 code composer 2000 I think maybe your .cmd file is worng, you can check you .cmd file and look at the map code and memory code.
May 31, 2004 #5 P petarpav Full Member level 5 Joined Mar 25, 2002 Messages 299 Helped 13 Reputation 26 Reaction score 5 Trophy points 1,298 Activity points 2,172 Re: code composer 2000 Hi, jgx. Can you upload drivers for 2402, and for 24x(if you have it)? Thanks.
May 31, 2004 #6 C Circuit_seller Full Member level 5 Joined Sep 23, 2002 Messages 300 Helped 17 Reputation 34 Reaction score 7 Trophy points 1,298 Activity points 2,350 Re: code composer 2000 Hi I think you hav placed a code which must run from RAM in the flash, so CCS makes this error. Try to locate it in RAM. Regards
Jun 2, 2004 #7 J jgx Member level 1 Joined May 21, 2004 Messages 33 Helped 0 Reputation 2 Reaction score 0 Trophy points 1,286 Location brazil Activity points 210 Re: code composer 2000 hi petarpav here some drivers from folder driver of code composer 1.tisim2xx.dvr 2.tisim5x.dvr 3.tixds24x.dvr 4.tixds2xx.drv and more... I hope that it's be useful for you?
Jun 2, 2004 #8 J jgx Member level 1 Joined May 21, 2004 Messages 33 Helped 0 Reputation 2 Reaction score 0 Trophy points 1,286 Location brazil Activity points 210 Re: code composer 2000 hi all please I need some examples of dsp 2402 or 2407 or 243 in assembler for application pwm and ports, and I confused with use cmd file thanks
