halee awan
Full Member level 3
antenna calc
hi to everyone
iam using the following RF(FM-RRF1 433c) module of www.okwelectronics.com
for our telemetry project....
the antenna specification that is mentioned in datasheet
by manufacturer for RX and TX
is as
1_ 34 Turns of enamelled copper wire diameter 0.5mm
close wound on 2.5mm diameter former
for helical antenna
2- Loop Antenna Area
4 To 10cm2 for loop antenna
3- 17.3cm @ 433MHz for wipe antenna
my question is that by which formula and conditions
Q1-the loop area (4_10cm^2) of antenna is calculated
as we know that the area of loop antenna S = N*pi*row^2 loop area
Q2-
By which factor 34 turn of 0.5mm diameter of copper wire is selected
hi to everyone
is as
for helical antenna
Q2-
