Help me with boosting the current of LM317
nikhilele
Advanced Member level 3
Bangalore India
LM317 boosting problem
I want to boost the current of LM317 or other regulator IC.
I have gone through data sheet of it and found the info over there
but not much useful for me
then i got other ckt digram too but it is using T0-3 type transistor
Can we have currents upto 4A using some BD series or TiP series To-220 type or such transisor
Re: LM317 boosting problem
TO-220 transistors are as good as transistors in TO-3 package ..
Quite often you can find the same transistors available in both packages, for example, 2N3055 (TO-3) and MJE3055 (TO-220) ..
Also you can use TIPs and BDs ..
For example:
TIP120
BD243 ..
and a good practice is to use more than one, all connected in parallel with small (0.1Ω) equalizing emitter resistors ..
In linear applications just keep in mind heat generation and equipe a power transistor with sufficient heatsink ..
Regards,
IanP
Thanks for your response Sir.
I am satisfied with your answers
Which diodes should be used for such rectifiers
I have 1N4007 but I think It won't handle >3A.
Which is next most widely available.
Rectifier diodes and diode bridges
Just check out the MUR series of rectifier diodes.
MUR860 is an 8A device
Giri
The next step up is the 1N540X series - 3A current .. see picture below ..
If you need more current you have to go for a bridge and if you intent to draw that current continuosly fit it with a small heatsink ..
Regards,
IanP
1N540x is widely used and it is easily available here.
thanks for pointing out that.
and u are talking about diode bridges like MDA series.
