Help me with address register issues in I2C and PIC18
Slayerza
Full Member level 5
South Africa
I have connected several MCU together on the I2C but, also I'm able to detect the srat and stop conditions so i know that the hardware is functional. However I can't seem to get an address match.
I know that in 7bit mode (currently using 7bit) the address is allowed to be 7bits with some reserved addresses. So 7bits can contain at a maximum 128 valid adresses. My question is this -
If the Adress register is 8bits and I write into it say 50 (0x32). If I then transmit the call to device 50 with a write (thus zero as bit 0) do i write 100 (0x64)?
Or have I got his completely wrong?
Cheers
Slayer
