nightdesigns
Newbie level 3
Incremental Relay
First off, I took a class in IC design a few years ago, but most of it is pretty foggy. I know my way around, but remembering how to build specific circuits is a wash. For all of you, this will be an easy one.
Here is what I want to do, I want to build a simple counter. Basically I have two inputs, A & B. They will control 10 outputs.
Each time you hit A, it will turn on the next output and turn off the previous. So for instance, If they're all off, and you press A, output 1 will turn on. If you press A again, output 1 will turn off, output 2 will turn on and so on.
B will be reset, turning off all outputs.
Can someone point me in the right direction to find a schematic, or provide me with the first few levels and I can do the rest.
Thanks!
Thanks!
