help me with a pic16877a
angelomary
Newbie level 2
jordan
Hello all:
am working in my final year project, i decide to use a pic16877a ,output to a buzzers & 8*8 Dot matrix, i try to implement my design using a protous simulator but there is no output while figure indicate there is a input so is my code wrong anyone know plz , my code listed below
program locator2
void main()
{char oldstate1 = 0;
char oldstate2 = 0;
char oldstate3 = 0;
char oldstate4 = 0;
char i=0;
trisa=0b00001111;
trisb=0x00;
trisc=0x00;
trisd=0x00;
trise=0b000;
porte=0;
portc=0;
portb=0;
do {
if (Button(&PORTA, 0, 1, 1)) // detect logical one on RA0 pin
oldstate1 = 1;
if (oldstate1 && Button(&PORTA, 0, 1, 0)) // detect one-to-zero transition on RA0 pin
porte.f0 = ~ porte.f0; // negates value on RE0
oldstate1 = 0;
} while(1); // endless loop
do {
if (Button(&PORTA, 1, 1, 1)) // detect logical one on RA1 pin
oldstate2 = 1;
if (oldstate2 && Button(&PORTA, 1, 1, 0)) // detect one-to-zero transition on RA1 pin
{porte.f1 = ~ porte.f1; // negates value on RE0
oldstate2 = 0;
do {
if (Button(&porta, 2, 1, 1)) // detect logical one on RA2 pin
oldstate3 = 1;
if (oldstate3 && Button(&porta, 2, 1, 0)) // detect one-to-zero transition on RA2 pin
if(i=0) {
portc=0b11001100;
portb=0b01010110 ;
i=i+1;
if(i=1) {
portc=0b01001100;
portb=0b01011110;
i=i+1;
if(i=2) {
portc=0b00001100;
portb=0b11011110;
i=i+1;
if(i=3) {
portc=0b01100100;
portb=0b11010110;
i=i+1;
if(i=4) {
portc=0b01011100;
portb=0b11000110;
i=0;
oldstate3 = 0;
}while(1); // endless loop
do {
if (Button(&PORTA, 3, 1, 1)) // detect logical one on RA3 pin
oldstate4 = 1;
if (oldstate4 && Button(&PORTA, 3, 1, 0)) // detect one-to-zero transition on RA3 pin
{ if(i=0) {
portc=0b01001100;
portb=0b11100111;
i=i+1;
if(i=1) {
portc=0b01010100;
portb=0b11110110;
i=i+1;
if(i=2) {
portc=0b01101101;
portb=0b11010100;
i=i+1;
if(i=3) {
portc=0b01011100;
portb=0b11011010;
i=i+1;
if(i=4) {
portc=0b01101110;
portb=0b10010110;
i=0;
oldstate4 = 0;
Added after 4 minutes:
also here is my circuit
matbob
Full Member level 2
KERALA
Hi angelomary,
I don't know whether there is anything wrong in your code. In Proteus simulation don't use those 'analog' resistors for pulldown or pullup purpose. You can find a model named 'PULLUP' in the parts list. It is a digital model of a resistor and it can make simulation (use only in digital circuits) faster and also ensures the correct logic states.
angelomary
Newbie level 2
jordan
thanks for your replay i tried to put a pullup resistor instead but no result even the switch dosent make a logic 1 to the pic while in analogue it was put a logic 1
matbob
Full Member level 2
KERALA
Hi angelomary,
I think I got it! You haven't set the port A pins as digital. By default, after power on reset, all the pins which can be used as ADC inputs are configured as analog inputs. To make all ADC pins digital, set 'ADCON1=0x7' during initialisation of port pins. Please refer 'ANALOG-TO-DIGITAL CONVERTER (A/D) MODULE' section in PIC16F877A datasheet for more details.
