stardust
Newbie level 1
Hi there
any one that knows assembley 8051 here?
I developed a program that lets me receive a character from terminal on serial port
compare it to the list that i have define and send message to the terminal that the character is received or is not on the list.
I need to do the same thing except that i need to be able to receive a string on a serial port and compare it with a list of string on the table ex table db: 4 'DANI' but I'm stuck.
I'll paste a code here
Thanks in advance if someone can help
ORG 0000H
LJMP MAIN
ORG 0023H
LJMP SEARCH
ORG 0030H
MAIN:
LCALL SERIAL_INIT
PRITJE: LJMP WAIT
SERIAL_INIT:
MOV A,PCON
SETB ACC.7
MOV PCON,A ;SMOD=1
MOV SCON,#52H ;ENABLE TI, MODE 1
MOV TMOD,#20H ;TIMER 1, MODE 2, 8-BIT AUTO RELOAD MODE
MOV TH1,#-35 ;1200 BPS AUTO RELOAD VALUE
SETB EA ;GLOBAL INTERRUPT ENABLE
SETB ES ;SERIAL INTERRUPT ENABLE
SETB PS ;HIGH PRIORITY FOR SERIAL INTERRUPTS
SETB TR1 ;START TIMER
RET
;TRANSMISSION OF ONE CHARACTER IN BAFER (SERIAL PORT)
OUTCHAR:
JNB TI,$
CLR TI
MOV SBUF,A
RET
;READING ON SERIAL PORT
SEARCH:
JNB RI,EXIT
CLR RI
MOV B,SBUF
MOV DPTR,#LIST
MOV R0,#00H
MOV A,'W'
RPT: CJNE A,#00H,PROCEED
MOV DPTR,#MESSG2
LCALL MESSG1
EXIT: RETI
PROCEED: MOV A,R0
MOVC A,@A+DPTR
CJNE A,B,PROCEED1
MOV DPTR,#MESSG1
LCALL MESSG
MOV A,B
LCALL OUTCHAR
LJMP EXIT
PROCEED1: INC R0
LJMP RPT
MESSG1:
MOV A,#0AH
LCALL OUTCHAR
MOV A,#0DH
LCALL OUTCHAR
MOV R1,#00H
RPT1: CJNE A,#00H,VAZHD2
RET
PROCEED2: MOV A,R1
MOVC A,@A+DPTR
LCALL OUTCHAR
INC R1
LJMP RPT1
LIST: DB 'A','B','C','D','E','F','G','H','I',00H
MESSG1: DB ' SEARCH COMPLETED SUCCSESFULY, CHAR FOUND : ',00H
MESsG2: DB ' THIS CHAR DOES NOT EXIST ON THE LIST',00H
END
ORG 0000H
LJMP MAIN
ORG 0023H
LJMP SEARCH
ORG 0030H
MAIN:
LCALL SERIAL_INIT
PRITJE: LJMP WAIT
SERIAL_INIT:
MOV A,PCON
SETB ACC.7
MOV PCON,A ;SMOD=1
RET
OUTCHAR:
JNB TI,$
CLR TI
MOV SBUF,A
RET
SEARCH:
JNB RI,EXIT
CLR RI
MOV B,SBUF
MOV DPTR,#LIST
MOV R0,#00H
MOV A,'W'
MOV DPTR,#MESSG2
LCALL MESSG1
EXIT: RETI
PROCEED: MOV A,R0
MOVC A,@A+DPTR
CJNE A,B,PROCEED1
MOV DPTR,#MESSG1
LCALL MESSG
MOV A,B
LCALL OUTCHAR
LJMP EXIT
PROCEED1: INC R0
LJMP RPT
MESSG1:
MOV A,#0AH
LCALL OUTCHAR
MOV A,#0DH
LCALL OUTCHAR
MOV R1,#00H
RET
PROCEED2: MOV A,R1
MOVC A,@A+DPTR
LCALL OUTCHAR
INC R1
LJMP RPT1
END
