pilot_ins_data=[zeros(nsym,6) par_data
,[1:nbitpersym/2]) zeros(nsym,1) par_data
,[nbitpersym/2+1:nbitpersym]) zeros(nsym,5)] ;
somebody please elaborate this part of ofdm code...this is the part of ofdm pilot insertion ....the whole code is as follows
close all
clear all
clc
nbitpersym = 52; % number of bits per OFDM symbol (same as the number of subcarriers for BPSK)
nsym = 10^4; % number of symbols
len_fft = 64; % fft size
sub_car = 52; % number of data subcarriers
EbNo = 0:2:12;
EsNo= EbNo + 10*log10(52/64)+ 10*log10(64/80); % symbol to noise ratio
snr=EsNo - 10*log10(52/64); % snr as to be used by awgn fn.
M = modem.pskmod(2); % modulation object
% Generating data
t_data=randint(nbitpersym*nsym,1);
% modulating data
mod_data = modulate(M,t_data);
% serial to parallel conversion
par_data = reshape(mod_data,nbitpersym,nsym).';
% pilot insertion
% fourier transform time doamain data and normalizing the data
IFFT_data = (64/sqrt(52))*ifft(fftshift(pilot_ins_data.')).';
% addition cyclic prefix
cylic_add_data = [IFFT_data
,[49:64]) IFFT_data].';
% parallel to serial coversion
ser_data = reshape(cylic_add_data,80*nsym,1);
% passing thru channel
no_of_error=[];
ratio=[];
for ii=1:length(snr)
chan_awgn = sqrt(80/52)*awgn(ser_data,snr(ii),'measured'); % awgn addition
ser_to_para = reshape(chan_awgn,80,nsym).'; % serial to parallel coversion
cyclic_pre_rem = ser_to_para
,[17:80]); %cyclic prefix removal
FFT_recdata =(sqrt(52)/64)*fftshift(fft(cyclic_pre_rem.')).'; % freq domain transform
rem_pilot = FFT_recdata
,[6+[1:nbitpersym/2] 7+[nbitpersym/2+1:nbitpersym] ]); %pilot removal
ser_data_1 = reshape(rem_pilot.',nbitpersym*nsym,1); % serial coversion
z=modem.pskdemod(2); %demodulation object
demod_Data = demodulate(z,ser_data_1); %demodulating the data
[no_of_error(ii),ratio(ii)]=biterr(t_data,demod_Data) ; % error rate calculation
end
% plotting the result
semilogy(EbNo,ratio,'--or','linewidth',2);
hold on;
theoryBer = (1/2)*erfc(sqrt(10.^(EbNo/10)));
semilogy (EbNo,theoryBer,'--*b','linewidth',2);
grid on
axis([0 12 10^-5 .1])
xlabel('EbNo');
ylabel('BER')
title('Bit error probability curve for BPSK using OFDM');
I NEED THIS FOR MY PROJECT..PLZ HELP !!!
