Help me translate subroutine from Assembly to Picbasic Pro
jojokatada
Full Member level 5
if portb high picbasic pro
hi could anyone help me to translate the subroutine in assembly to picbasic pro
i want to use pic16f877a and checking each bit of portb if it is high then porta corresponding bit set to high
here is the assembly subroutine
checking portb
btfsc portb, 0
bsf porta, 0
btfsc portb, 1
bsf porta, 1
btfsc portb, 2
bsf porta, 2
btfsc portb, 3
bsf porta, 3
return
appreciate for anyone could help
translate from assembly to picbasic
easy...
LOOP:
TRISA=$ff 'port a is input
TRISB=0 'portb is output
PORTB=PORTA
GOTO LOOP
Added after 27 seconds:
easy...
LOOP:
PORTB=PORTA
GOTO LOOP
Re: subroutine for picbasic
appreciate but that not a subroutine for picbasic pro and i want to check each individual pin not the whole port
trisb=$FF
trisa=0
checking portb:
if portb.0=1 then porta.0=1
if portb.1=1 then porta.1=1 ; etc.
return
but it has no sense; if portb.0 returns to '0', porta.0 still remains on '1'.
yo5oqa said:
trisb=$FF
trisa=0
checking portb:
return
where do i put the endif ?
is it ok every end of if
if portb.0 =1 then porta.0 =1
endif
If there is a single instruction after 'then', on the same line, you don't need 'endif';
... if you have more than one it is like this:
if portb.0=1 then
porta.0=1
portc.0=1
endif
if ... then
endif ; etc
