Rickooo
Member level 3
Wiring goes right. Their isn't any part damage and connection is also right. I also check from oscilloscope and multimeter. But, What I observe, while testing with a multimeter without load is:1 + 2 is expectable, as already explained along this thread. 3 + 4 is not expectable, there's presumedly a wiring error or defective part.
CIRCUIT 1 & CIRCUIT 2:
-> LED- = 0 and LED +(Vo)= Vin
-> At VCC pin (which is PIN 5 of FL7760) i got 4.9 V and hence, these circuit are working fine.
In CIRCUIT 3 & CIRCUIT 4:
-> LED - = 0 to Vin (pulse) and LED + = 0 to Vin (pulse). I don't understand why.
-> At VCC pin (which is Pin 5 of FL7760) i got 0.12V and hence, this circuit is not working.
All connections are right. What do I do know. What do you think, why this happen.
--- Updated ---
@FvM Is there something with the IC, which it only work for current above than 1.5A?
