tigerkonsole
Junior Member level 3
hi,
can any body help me to interface the pic16f877 with usb port :?:
It really depends on what you mean by "direct interface". If you are implying using a microcontroller to generate usb signals, google for IgorPlug. Otherwise, if you are implying using a dedicated usb node controller, you can use any of those that cyberblak listed. I would just like to add National's usbn9603/4 to the list.stalemate said:The quickest route is to interface an FT232BM from ftdichip.com to the chip's serial port. This will enable the microcontroller to communicate with PCs and other USB hosts. It won't enable the microcontroller to access USB peripherals
i think its not posiible to have direct interface of usb with the pic
