help me to design high power coupler and detector!
footprint
Member level 5
microstrip coupler detector
It is about X band.........
How to deign it ?
who help me ?
best regards!!
One would start by defining what the exact frequency range is, the coupling value, maximum input power, altitude, the directivity required, and the media desired (coax, waveguide, microstrip, stripline).
For the detector, one would define what is the dynamic range required and response time.
I wanna use microstrip circuit! it's about 20W PA
the detector is used to test it!
Added after 3 minutes:
Can you give me some help,thanx a lot!
use overlay coupler, about 20dB (so u gona have good directivity)
put att after the coupler, and then Analog devive comp. made agood ditector 0-18GHz. (i teset it, and it is ok).
thank you very much
Added after 14 minutes:
but how to design a overlay coupler and what's mean of "att"...........
I'm sorry of less know about this!
footprint said:
thank you very much
att is attanuator
to make an overlay coupler u should put dielectric metiral on the coupler
But I still don't konw how to choose and design the detector with diode!!!!!!
at what freq ?
X band about 9-10GHz
hoho~
help me pls
