Help me switch to AVR32 from AVR
MohammadElwakeel
Junior Member level 1
Hi everyone,
I have been using AVR for about 3 years know. I was thinking about switching to AVR32 . anybody knows how to start in AVR32. what kit to buy, is it the EVK1100 or the EVK1101 or the NGW . any one please tell me is it really worthy time to spend in this controller and how to stat. please tell me how to start fast and stright forward.
thanks
avr32 parallel port
Hi
First start by going to the Atmel web site and have a look at the documents.
Depending on what you need you can look at the AP7000 devices.
full blown with MMU and support for linux image etc. but no on board flash
on board graphic controller etc . Good for doing PDA like apps.
The new UC3 devices is better suited for native programming
the devices have 128 to 512k of on board flash and n nice spread of interfaces.
The Avr32 studio tools can be downloads from the Atmel web site ( Around 200Mbt)
if you need the linux BSP you need to download the BSP as well ( around 500Mbt)
Alltogether very nice devices.
You dont need to buy the STK1000 to get going the smaller dev kits have enough to get going
Regards
WB
Switching to AVR32
hi
i have a question. can the EVK1100 be programmed via usb with no external component or i need JTAG mkII to program it.
Re: Switching to AVR32
avery AVR micros are very sililar u can make your programmer yourself with using parallel port.download stk200/300 cable connection and program your micro serially.
Switching to AVR32
hi
another question concerning STK1000. when I buy the 534$ kit. does the price include the two boards (the mother board and the daughter board) or it is just for the mother board.
Hi
Inclues the lot :
STK1000 provides a complete AT32AP7000 development environment. The kit has two ethernet ports, a high quality QVGA LCD, a loudspeaker, and connectors for USART, PS/2, VGA, and USB. A expansion header can be used for prototyping.
A pre-installed Linux image on the enclosed 256 MB SD card ensures that the user can boot Linux and start program development directly after power up.
STK1000 is also supported by AVR JTAGICE mkII. With either GNU GCC or the IAR compiler, the JTAGICE mkII supports basic runtime control and a limited trace.
The Vitra and the Opella products from Ashling supports provide high-end debugging capabilities as e.g. sustained trace and SQA (software quality assurance). An extensive white paper is available at www.ashling.com (PDF).
Ordering Code: ATSTK1000
wb
