Roel
Member level 2
STN 256 Color Display
we 're currently experimenting with a STN color display to make 256 colors.
The display is a 8 color display: each pixel consists of 3 colors, red, green and blue and each color consists of 1 bits. So you can make 8 colors.
Now we developed some logic to produce more colors: each pixel still consists of 3 colors but now, each color has 3 bits.
We made a frame counter and make more colors to change the color between the frame.
An example: If you use the display in 8 color mode, the red color of pixel n° 1 has one bit, so you can turn it on or off, that's all.
In the new system, this red color of pixel n°1 has 3 bits, so if, for example, you send an 8, then the red color is on for 7 successive frames, if you send a 0, then it is never on, if you send a 1, then this red color of pixel 1 is 1 frame on and 6 frames off,......
The problem is that the display flickers.
That seems very strange because the optics of the display has a response time of 300 ms rise time and 80 ms fall time......
If we do a test and make a full screen that is 5 frames red and one frame off, it flickers with a frequency of approximately 10Hz.
The refresh rate is 60 Hz, higher refresh rates are no option (too much load on the processor).
Any suggestions?
The method we apply is the same as used in the famous display controllers such as the Epson?
Any suggestions?
