Help me solve the error in the code!
brahma
what is the problem?
BEGIN
process
begin
if s1 ='0' and s2 ='0' then
q1: ask port map(x1,y1,c1); ( i get error)
else if s1 ='0' and s2 ='1' then
q2: askdemod port map(x,y,c); ( error)
end if;
end process;
in this code i get error.
"gp.vhd",line 66: Error, syntax error near 'process'.
"grouping_gp.vhd",line 59: Error, syntax error near 'port'.
i use modelsim simulator, i dont know how to solve this error can anyone help me??
bbgil
Full Member level 2
Re: what is the problem?
for one, i think you syntax of else if should be elsif. Another check your port mapping syntax. Iam not sure about ask command. hope this help.
gliss
Advanced Member level 2
It doesn't appear 'ask' is valid VHDL. You might want to post the entire module you are tyring to compile.
tkbits
Full Member level 5
I don't think you can create components within a process.
If these are functions you're trying to embed, then you probably need to put the functions in a package and use function calls, rather than instantiation syntax.
brahma
1. bbgil- i also tried elsif i got the same problem
2. gliss-'ask' is not a command word in VHDL i've done port mapping. 'ask' is the entity name where i've mapped to.
3. tkbits-i tried without that process command, no change, same problem exists.[/quote]
tkbits
Full Member level 5
And you can't use if outside a process.
What are you trying to accomplish by instantiating within an if? Entities don't "inline".
brahma
the thing i've done is i've written two different code one for ask and another for askdemod, if the select lines s1 and s2 are 0 then ask has to be called (i.e. portmap) else askdemod has to be called. this is what i want. am i clear to u???
sree205
Advanced Member level 1
hi, shouldn't there be a sensitivity list for the process ?
sanjana
Junior Member level 2
hi
why don't u try to use "generate" statement.
It works well in the process.
Added after 22 minutes:
otherwise U instantiate the components outside the process statement.Assign the signals in the process block.Use enable signal to select ur components. that will do.
