Help me solve a TCP segment transmission task
danesh
Full Member level 3
hi guys,
anyone could help me solve this problem ?
A TCP segment consisting of 1500 bits of data and 160 bits of header is sent
to the IP layer, which appends another 160 bits of header. This is then
transmitted through two networks, each of which uses a 24 bits packet header.
The destination network has a maximum packet size of 800 bits. How many
bits, including headers are delivered to the network layer protocol at the
destination?
thanks appreciate your help and comments
Re: TCP
Hi
I cant understand your question completly butI wish the followingcan help u.
in the network there is a logical link between layers. so eachlayer can divide the upper layers packet into small packets and then add to them its header. and u should consider that two computer want to comunicate with each other through a network both of them should use the same protocol that is for example both of them should use TCP/IP then each packet size than the source use the destination use the same size.
