interconnects
Newbie level 3
I want to use Q3D to simulate a simple interconnects structure, a signal line with three ground line on each side, as illustrated below.
G1 G2 G3 S G4 G5 G6
All the ground lines are the return path of the signal line, which means the sum of the return currents in the ground lines is equal to the current in the signal line.
How can I set up this structure in Q3D?
G1 G2 G3 S G4 G5 G6
