Help me select FPGA for implementing graphic primitives on it
honnaraj.t
Member level 2
hi ,
last week i join in MNC, they told implement the graphic primitives on fpga... basically graphic primitives are implemented in sotware in graphics.. but inorder increase the speed and fuctionality of the graphic processor...we are implementing these on FPGA. problem is just now i finished my M.TECH.. i am not getting HOW TO select FPGA .HOW TO CREATE BLOCK DIAGRAM FOR MY PROJECT. PLEASE HELP REGARDING THIS PROJECT
ship_baba
Member level 4
Re: FPGA IMPLEMENTATION
hi dude,
from which university, did you finished M.TECH,don't tell IIT or IISc or BITS
regards,
sam
darylz
Full Member level 2
FPGA IMPLEMENTATION
Do you have any idea about your design?
1. How big is the logic?
2. How much on-chip memory is required?
3. Do you need off-chip memory? What's the type? SRAM/SDRAM/DDR/DDR2/RLDRAM..
4. How many pins are needed?
5. What's the IO standard?
tayyeb1
You never just start with FPGA.First you design the algorithm.then test it using some simulator(matlab etc).Then you start converting it in digital hardware.Then you compare the HDL simulation results with matlab results.Once successful,It s time to choose your FPGA according to design constraints.
Understood......
shield
Junior Member level 3
FPGA IMPLEMENTATION
how to start a design is a big problem for the newer. Who can give some suggestion?
mta97e
Member level 1
look at the appropriate application notes from the vendor website.... i believe is the fastest way to pick up things..
both altera and xilinx provides good materials on their websites..
get a development board and try out the application notes .... and VOLA ... u will become a guru in no time..
seriously ...
there are 100s of appliccation notes ...
fpga_user
Newbie level 2
FPGA IMPLEMENTATION
I'm a begginer in FPGA and I want to programm a PID control
with VHDL for a DC-DC buck converter.
I have Spartan-3E Starter Kit (XC3S500E-FG320-4c)
and ISE8.1.
1)I need to read 2 analog signals, voltage and current
This kit have a dual gain amplifiers and 2 simultaneous
sampling ADC.
2)I'll generate a PWM output signal, which is a function
of the first 2 signals.
I saw a PicoBlaze ADC file, but how can use this application
or how can to modify this code to my application???
Can you give me some help how to handle an input signal
to create an output that I can use in my vhdl code.
