Help me select enough RAM for IC 5141
safwatonline
EGYPT
hello,
i am just installing IC 5141 on my computer , but it is really really slow , i want to know what is the good size of RAM for fast operation , i have P4 2.4 GHz processor
thnx,
A.SAFWAT
Re: hardware requirment
Hello!
You will verify on your system the mode DMA.
hdparm /dev/hda
The variable using_dma must be stay on "1 (on)"
I am so think!
Shurik said:
Hello!
hdparm /dev/hda
I am so think!
That's only if he has IDE drives. SCSI is much faster.
safwatonline,
1GB or more I would say is good.
Shurik said:
Hello!
hdparm /dev/hda
I am so think!
huh ! i dont understand a single word :D
plz take plain english as i am ignorant in linux,
thnx,
a.safwat
safwat,
he has saying to check to make sure you're IDE (ATA) subsystem is operating with direct memory access (DMA). This can speed up reads and writes to the hard disks. This can speed up your application if it's using a lot swap space.
Go to a root prompt and type:
/sbin/hdparm /dev/hda
If you have IDE disks, it will show you if you DMA enabled or not.
Run hdparm on whatever disk the swap space is located, and / and your IC application.
    safwatonline
hardware requirment
I think,the P4 2.4 GHz processor is enough.
hardware requirment
what do you meen by "slow" ?
hardware requirment
P4 2.4 GHz processor should be enough, check your OS or other APP slow or fast
