Re: Moon Tracking Sytem
I did something similar, and I noticed that a common way of doing it was to use some sort of 'grid scanning' algorithm, and then once you have found the moon, switch to a different algorithm which just moves in a small circle or square, just to make minor adjustments as the moon moves.
Another technique is to use more than one photo-cell, and compare the output from each photocell, in order to find the highest amplitude, so you know directly which direction to move in. This is much harder, this is the method I tried.
