help me on this problem!!
eda_range
Member level 1
Look at the pic here. A is the non-reversed input port, B is reversed input. All the transistors are PMOS and Idc is the bias current for amp6. Theredically, the voltage of A should equal with B.but the simulation results show that if P3 is on, VB quickly reaches approximately VDD.And the voltage of node C finally attends to a very low potential.
Please tell what's wrong with this ckt?
Thank you!
eda_range
Member level 1
Anyone please kindly give me a clue, thank you.
northeast1
Full Member level 2
Thank you!
you should exchange A and B terminal. and try
Best regards
Ben
eda_range
Member level 1
I have the same result after change A and B terminal...
rainman.cn
Member level 2
how can you determine the gate voltage of p1,3,6, ?
eda_range
Member level 1
Thank you for your replies.
the A is the input signal , the gate voltage should be determined by A. And as I imagine the current through P3,P4 will be variable while VA is changing.
Additionally, the drain of P2 and P5 is floating.
rainman.cn
Member level 2
you take no effort to stabilize the quiescent point of the ckt, i think. you should add a valid dc neg feedback.
