Dec 18, 2010 #1 A amiraa Newbie level 5 Joined Dec 18, 2010 Messages 9 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Activity points 1,331 hi I need for your experience I wil prorming by mikroc the measur of motor by encoder then I will placed in proteus help me
Dec 18, 2010 #2 andre_luis Super Moderator Staff member Joined Nov 7, 2006 Messages 9,593 Helped 1,190 Reputation 2,399 Reaction score 1,207 Trophy points 1,403 Location Brazil Activity points 55,667 What exactly you need ? +++
Dec 18, 2010 #3 A amiraa Newbie level 5 Joined Dec 18, 2010 Messages 9 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Activity points 1,331 I need for the schema in protues or any idea for programing with mikroc thanks
Dec 18, 2010 #4 andre_luis Super Moderator Staff member Joined Nov 7, 2006 Messages 9,593 Helped 1,190 Reputation 2,399 Reaction score 1,207 Trophy points 1,403 Location Brazil Activity points 55,667 Well, Due rate of pulses is commonly very high, is not a good solution achieve it at firmware. You must use an encoder counter performed by hardware. Depending on what uC you´re using, it may have a built-in capture module to count this. Check this : Rotary Encoder Circuit | Electronic Circuit Directory +++
Dec 18, 2010 #5 A amiraa Newbie level 5 Joined Dec 18, 2010 Messages 9 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Activity points 1,331 I will placed pic+motor_encoder+lcd for displaying
Dec 18, 2010 #6 bigdogguru Administrator Joined Mar 12, 2010 Messages 9,821 Helped 2,350 Reputation 4,694 Reaction score 2,272 Trophy points 1,413 Location Southwest, USA Activity points 62,383 Hi, Here's a few examples of using an encoder with motor control: Using Encoder **broken link removed** SENSORS - ROBOT ENCODER Also check out: Circuit Cellar's Current Issue Dec 2010 Issue 245 These should get you going in the right direction.
Dec 18, 2010 #7 A amiraa Newbie level 5 Joined Dec 18, 2010 Messages 9 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Activity points 1,331 thanks for your job with me ---------- Post added at 22:57 ---------- Previous post was at 22:52 ---------- I will placed in my schema pic16f877 + motor_encoder + lcd for displaying
Dec 19, 2010 #8 A amiraa Newbie level 5 Joined Dec 18, 2010 Messages 9 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Activity points 1,331 help meeeeeeeeeeeeeeeeeee
Dec 19, 2010 #9 andre_luis Super Moderator Staff member Joined Nov 7, 2006 Messages 9,593 Helped 1,190 Reputation 2,399 Reaction score 1,207 Trophy points 1,403 Location Brazil Activity points 55,667 amiraa, Be shure you probably will not receive a complete project. So, the best thing to do is post here each problem you find, according it happens. +++
Dec 27, 2010 #10 A amiraa Newbie level 5 Joined Dec 18, 2010 Messages 9 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Activity points 1,331 I have a problem with dislaying speed of motor
