Help me install Cannon Pixma 1000i printer on Linux
earlybird23
Junior Member level 2
I want to install canno printer(pixma 1000i).
can any one help me?
Ragnarok83
Member level 3
Colombia
Re: linux software.
Check with CUPS V1.1.x is the best software for get drivers for printers.
III
Full Member level 5
Macedonia
linux software.
What distro are u using?
in most distros just plugin the printer and restart your pc the hardware scan dureing boot shuld detect your hardware and load the aproriate kernell modules aka drivers.
earlybird23
Re: linux software.
My linux distribution is Redhat9.
please help me.
regards
sagar
III
Full Member level 5
Macedonia
linux software.
I don't know redhat 9 I think it's a bit old and if it uses the 2.4 kernel that culd be a problem as most plug and play hardware support is built in the kernel, I'd suggest upgrading to fedora 6 (if you're a redhat fan) or to opensuse 10.2.
did you check with cannon's support forums?
I know that my epson wasb't supported in the 2.4 kernels but with the 2.6 it was even the two year old suse 9.1 (the first distro to ship with the 2.6 kernel) supported it?
III
Full Member level 5
Macedonia
linux software.
just searched the world of linux for your printer and this is what i can tell you!!!
goto PIXMA iP1000
and dll the binary modem driver
iP1000Linux.tar.gz 8655.89 Kb.
and the Manual
guidepixmaip1000-2.50-1.tar.gz 3849.09 Kb.
unfortinetly as I'm behind a firewall and PIXMA iP1000 uses asp technology so I can't acces the direct links.
What I've learned is that this driver has been used in rpm based distros as suse, redhat and mandrake, and debian based distro's via alien.
III
Full Member level 5
Macedonia
linux software.
Hey it's been a few days and no news :(.
Did you get the printer to work with the driver suplied by canon? I noticed that it was compiled for suse and you said that you're driving redhat.
Shurik
Full Member level 3
Re: linux software.
Hello!!!
Are you installed your printer ?
If didn't, then try utilize the command redhat-printer-config
