Help me in SOC encounter............
ramesh441
India
soc encounter shell commands
Hello Sir,
After typing "encounter &" in terminal I am getting the following code as below and opening encounter
but from then there is no response its get hang up...
can any one help me please...........
Thanks in advance
This version requires license using cdslmd daemon.
Checking out Encounter license ...
SOC_Encounter_GPS 6.2 license checkout succeeded.
INFO: Current OA version selected: OA22
Starting console server on port vlsi03:8888 ..
sourcing /cad/cadence/SOC62/SOC62/tools.lnx86/fe/etc/rdaDSL.tcl
* Copyright (c) Cadence Design Systems, Inc. 1996 - 2007. *
* All rights reserved. *
* This program contains confidential and trade secret information *
* of Cadence Design Systems, Inc. and is protected by copyright *
* law and international treaties. Any reproduction, use, *
* distribution or disclosure of this program or any portion of it,*
* or any attempt to obtain a human-readable version of this *
* program, without the express, prior written consent of *
* Cadence Design Systems, Inc., is strictly prohibited. *
* Cadence Design Systems, Inc. *
* 2655 Seely Avenue *
* San Jose, CA 95134, USA *
@(#)CDS: First Encounter v06.20-p006_1 (32bit) 01/29/2007 21:55 (Linux 2.4)
@(#)CDS: NanoRoute v06.20-p009 NR070127-0950/USR45-UB (database version 2.30, 45.1.0) {superthreading v1.6}
@(#)CDS: CeltIC v06.20-p007_1 (32bit) 01/17/2007 22:29:02 (Linux 2.4.21-37.ELsmp)
@(#)CDS: CTE v06.20-p008_1 (32bit) Jan 25 2007 03:39:44 (Linux 2.4.21-37.ELsmp)
--- Starting "First Encounter v06.20-p006_1" on Thu Apr 16 00:41:44 (mem=59.5M) ---
--- Running on vlsi03 (x86_64 w/Linux 2.6.9-22.ELsmp) ---
This version was compiled on Mon Jan 29 21:55:17 PST 2007.
Set DBUPerIGU to 1000.
Set Default Mode Capacitance Scale Factor to 1.00
Set Detail Mode Capacitance Scale Factor to 1.00
Set Coupling Capacitance Scale Factor to 1.00
Set Resistance Scale Factor to 1.00
Set net toggle Scale Factor to 1.00
Set Shrink Factor to 1.00000
wpchan05
Full Member level 4
you should type encounter only in your terminal. No ampersand (&) please.
kumar_eee
Advanced Member level 3
Bangalore,India
& forces the process to operate in background mode.. you can type "fg" get the encounter shell..
    ramesh441
ramesh441
India
When I type encounter fg
encounter is opened and got closed saying
"Error in startup script: couldn't read file "fg": no such file or directory"
in the terminal
kumar_eee
Bangalore,India
hey, common.. u should not type "encounter fg"... fg is a unix/linux command used to bring the background process.
launch encounter using "encounter -license type"...
example:
cmd>encounter -fexl
cmd>encounter -socel
cmd>encounter -nanor
here -fexl,-socel & -nanor are different license options.
Hope this helps..
jeevan.life
Full Member level 5
Bangalore
If you type encounter & , then you can type fg to get the shell. Also bg can be used to send any process to background.
