help me in reducing the spikes in inverter
prasadel06
Member level 2
hi....
i am using inverter in my project....i am using 130 nm tech...
and i am getting spikes...please help me in reducing the spikes in
the output of the inverter...
thank you..
prasad
carv_13
Member level 2
can you post a snap of the spikes that you are getting?. Did you try increasing the width of the PMOS?.
barrybear
Full Member level 4
Where ever you get a very high speed swithing junction you will get a spike. try a little decoupling. Shunting with a small capacitor.Diodes can also help as clamps,
funnynypd
Banned
USA & Canada
Diode and cap will definitely help. The cap might slow down the max speed.
prasadel06
Member level 2
hi....
here i am using 130 nm tech and with cap 2.5f
here i am attaching snapshot of output..
thanks
[/img]
phutanesv
Full Member level 3
prasadel06 said:
hi....
thanks
Then u need to adjust with the width, make sure that pmos is 2or 3 times more the width of nmos .
Also just see if ur are geting the rise time and fall time properly for that
capacitor value.
Regards
Phutane
onlymusic16
Full Member level 2
Yes i also agree to what other members are saying. It seems the sizing is the culprit here. Adjust the width of the mosfets (it would be wrong to quote any number here) but let me take a guess, your wp & wn must be large. Is your wp >1. if yes, get it down because it has to drive only a small cap of 2.5f.
ericyuan
Member level 1
Wp/Wn=2.7
try to control the trip-point at the middle of the full voltage
