Help me in AT Commands in Sim300
aameer
Full Member level 4
Full Member level 4
Bangalore
hello friends,
i am using Sim300 gsm module. When Dial a number with ATD+91XXXXXXXXXX;<enter>.... the phone will ring.If receive or busy or when phone is off it is getting NO CARRIER as reply.
I want to know the status whether the dialed number person received the call or his phone is out of reach or didn't he pick up the call.
To know the above conditions what are the commands should be used so that i can know the condition of the call made.
Thanks in Advance
Aameer
Once number is dialled with ATD Command GSM module responses the status of the dialed number.
For no connection it gives "NO CARRIER"
If busy it response "BUSY"
If connection successful ie. person picks up the call "OK"
but from my GSM module it is giving NO CARRIER for the all above mentioned condtions...
is there any other commands to check
can u tell me what is the response when u receive the call from GSM and when u not receive the call from GSM....
If phone rings or busy or received or phone is off.. feed back is NO CARRIER
