Kekkaishi
Member level 1
Modem
I need to construct simple infra red modem. the schematic is like below.
After constructing it on breadboard, I think I got few new ideas to enhance it but I need some advice from the expert.
For case
1: I think I would lik t replace all of the component with just a normal voltage regulator like LM7805 but after a googling I found out that LM7805 with two capacitor(to regulate to 5v voltage) only produce current <1mA. So may I know is there any other component that I can use to replace them?
2: Is there any dual 2input NOR gate THT component? I only fount SMT component for this NOR gate to replace 4001B.
3. I think I want to increase current for the collector pin of 2N4401 so that I can increase the intensity of the IR LED. In order to achieve it, I found out to ways, one of them is to use bjt that have higher Beta and the other one is to increase the base current of the 2N4401. To increase the base current I need to redue the 10k resistor vaue but I need help on the calculation. May I know what other bjt that can be used which has higher beta value than 2N4401? and anybody can help me with the calculation of base current?
Thank you for all your helps.
For case
