Help me for making the source code for the schematic (asm & hex file)
India, Kerala, Moolamattom
Help me anybody to create the source code for the schematic (asm & hex file) attached...This all my own idea...nd its use for to protect the household equpiments like TV,Music System, Light Unit etc..
Help me anybody please..........
  • SCHEMATIC.PDF
actually your schematic is incomplete.... mention the ports on which you want the output.... and also the input port....
that is your choice....i want only the correct result.....
---------- Post added at 20:02 ---------- Previous post was at 19:56 ----------
sir,
Please see this schematic...i know that the schematic is incomplete...but i know, something about the microcontroller.....its need crystal oscillator, reset switch, etc...if i draw the above components, the circuit will looks more complicate......
so please make for me source code.....and you suggest the input and output port.....that is your choise.....but i want the correct result what i want.....
Thanks again for your replay...
If you cant help me, its OK. But I pray for you always for your good and nice mind to help someone.......
*** bless you......
thanks again...
  • SCHEMATIC new.PDF
