Register Log in
Help me for LDO capacitor selection
niks
Full Member level 3
hello,
What is the recomended value of input and output tantalum/electrolytic capacitor LDO? What is the standard way to calculate these values or any formula?
Can anyone give me guidelines or application notes for it?
I am using few LDO in my design. One of them is TPS7953.
thanks in advance
niks
memarian
Full Member level 5
Dear,
Usually a 10uf~100uf Tantalum for input and same for output is enough but
some regulator needs at least 47uf or higher.check your ic datasheet.
(I searched google for TPS7953 and i found nothing!)
GoodLuck.
niks
Full Member level 3
Thanks for the answers. Datasheet gives information about the ceramic capacitor. But i also want to add Electrolytic/Tanta capacitor. Then what should be the value? Any formula to calculate these values?
Regards
Nikhil
huojinsi
Full Member level 5
No special formula can calculate the ESR of capacitor. Good fabricator of capacitor will provide a range of capacitor ESR. u had better choose the capacitor according to the information of IC datasheet, only like so,ur application is the best!
Toggle Sidebar
