kokei74
Junior Member level 3
portmap technique
i tried to perform a multiplication using port map technique. For some reason its getting an error. Can some1 help me fix this and tell me the reason?
library ieee;
use ieee.std_logic_1164.all;
entity Phase1 is
port ( clk :IN std_logic;
Mulresult :OUT std_logic_vector (15 downto 0));
end Phase1;
architecture logic of Phase1 is
signal s0 : std_logic;
signal s1 : std_logic;
signal s2 : std_logic;
signal s3 : std_logic;
component CounterA
port (clock : IN STD_LOGIC;
q : OUT STD_LOGIC_VECTOR(3 DOWNTO 0));
end component;
component CounterB
end component;
component ROMA
port (ADDR : in std_logic_vector (3 downto 0); -- address input
DOUT : out std_logic_vector (7 downto 0)); -- data output
end component;
component ROMB
port ( ADDRB : in std_logic_vector (3 downto 0); -- address input
DOUTB : out std_logic_vector (7 downto 0)); -- data output
end component;
component mul
port (a : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
b : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
result: OUT STD_LOGIC_VECTOR (15 DOWNTO 0);
begin
stage0 : CounterA port map (q =>s0,clock=>clk);
stage1 : CounterB port map (q =>s1,clock=>clk);
stage2 : ROMA port map (ADDR =>s0,DOUT=>s2);
stage3 : ROMB port map (ADDRB =>s1,DOUTB=>s3);
stage4 : mul port map (a =>s2,b =>s3,result=>Mulresult);
end logic;
library ieee;
entity Phase1 is
end Phase1;
component CounterA
end component;
component CounterB
end component;
component ROMA
end component;
component ROMB
end component;
component mul
begin
end logic;
