viks
Member level 1
Guys
I am tired with this problem ,please help me out here.
I am trying to communicate over CAN network.
I have two 18F4580
one as Transmitter and another as Receiver.
I am not able to get any data from Trans to Receiver.
Code as follows
Transmitter.
list p=18f4580 ; list directive to define processor
radix dec
#include <p18f4580.inc> ; processor specific variable definitions
;************ Identifier is 123H
BRGCON1_CONST EQU 0x03; SJW = 2 Tq, BRP = 3
BRGCON2_CONST EQU 0xA1; Seg2 freely programmable,
; 1 samples/bit, Ph1 = 5 Tq, Prop seg = 2 Tq
BRGCON3_CONST EQU 0x01; Seg2 = 2 Tq ---> Sample at 80%
START_CAN EQU 0x08; request normal mode, abort all xmissions, TXB0 in access bank
TXB0CON_CONST EQU 0x03; value to be loaded into TXB0CON to allow write access to TXB0
; requests message abort, set buffer priority to 3 (highest)
TXB0CON_SEND EQU 0x08; requests that TXB0 be sent on CAN bus
DLC_CONST EQU 0x08; value for DLC field of message
CIOCON_CONST EQU 0x20; value to load into CIOCON
; Drive TX pin to Vdd, no CAN Capture function on RC2
goto start
;main_code code 0x2A
org 0x002A
start
movlw b'11111011' ; RB2 is output (CANTX)
movwf TRISB
; set up PORT D for use with LED on RD0, pulled up to Vcc.
movlw 0x00 ; All Port D pins are outputs
movwf TRISD
movlw 0x0E ; initialize LED to ON (D0=0), rest to OFF (D1, D2, D3 = 1). LCD data = 0 (D74)
movwf PORTD
movlw TMR0_OFF ; sets up timer 0, but does not start it counting
movwf T0CON
; initialize CAN for TX Buffer 0
movlw CIOCON_CONST
movwf CIOCON
movlw 0x98 ;Configuration mode with buffer 0 selected.
movwf CANCON
check1:
btfss CANSTAT, OPMODE2
bra check1
movlw BRGCON1_CONST
movwf BRGCON1
movlw BRGCON2_CONST
movwf BRGCON2
movlw BRGCON3_CONST
movwf BRGCON3
movlw START_CAN
movwf CANCON ; start CAN in Normal Mode
; set up TX Buffer 0
movlw TXB0CON_CONST
movff WREG, TXB0CON ; use movff as TXB0CON is in bank 15
movlw 24H
movff WREG, TXB0SIDH
movlw 60H
movff WREG, TXB0SIDL
movlw DLC_CONST
movff WREG, TXB0DLC
; Load up Constant Data Bytes
movlw 0
movff WREG, TXB0D0
movlw 1
movff WREG, TXB0D1
movlw 2
movff WREG, TXB0D2
movlw 3
movff WREG, TXB0D3
movlw 4
movff WREG, TXB0D4
movlw 5
movff WREG, TXB0D5
movlw 6
movff WREG, TXB0D6
movlw 7
movff WREG, TXB0D7
; set request to transmit message
movlw TXB0CON_SEND
movff WREG, TXB0CON ; request sending TXB0 on bus
end
Receiver
START_CAN EQU 0x00; request normal mode, abort all xmissions, TXB0 in access bank
;************ initial *******************
goto start
org 0x002A
start
CLRF PORTA
MOVLW 0xff
MOVWF TRISA
MOVLW 0xff
MOVWF TRISC
CLRF PORTB
MOVLW 0xFB
MOVWF TRISB
movlw CIOCON_CONST
movwf CIOCON
movlw 0x90 ;Configuration mode with buffer 0 selected.
movwf CANCON
check1:
bra check1
movlw BRGCON1_CONST
movwf BRGCON1
movlw BRGCON2_CONST
movwf BRGCON2
movlw BRGCON3_CONST
movwf BRGCON3
movlw START_CAN
;setup Rx Buffer
movlw 0x60; // Set to ignore all filters, masks
movwf RXB0CON
Nomessage BTFSS RXB0CON ,RXFUL
BRA Nomessage
MOVFF RXB0D0,var0
MOVFF RXB0D1,var1
MOVFF RXB0D2,var2
MOVFF RXB0D3,var3
MOVFF RXB0D4,var4
MOVFF RXB0D5,var5
MOVFF RXB0D6,var6
MOVFF RXB0D7,var7
BCF RXB0CON ,RXFUL
MOVFF var5,PORTA
MOVFF var6,PORTC
goto Nomessage
end
I have two 18F4580
Code as follows
Transmitter.
radix dec
goto start
org 0x002A
start
movwf TRISB
movwf TRISD
movwf PORTD
movwf T0CON
movlw CIOCON_CONST
movwf CIOCON
movwf CANCON
check1:
bra check1
movlw BRGCON1_CONST
movwf BRGCON1
movlw BRGCON2_CONST
movwf BRGCON2
movlw BRGCON3_CONST
movwf BRGCON3
movlw START_CAN
movlw TXB0CON_CONST
movlw 24H
movlw 60H
movlw DLC_CONST
movff WREG, TXB0DLC
movlw 0
movff WREG, TXB0D0
movlw 1
movff WREG, TXB0D1
movlw 2
movff WREG, TXB0D2
movlw 3
movff WREG, TXB0D3
movlw 4
movff WREG, TXB0D4
movlw 5
movff WREG, TXB0D5
movlw 6
movff WREG, TXB0D6
movlw 7
movff WREG, TXB0D7
movlw TXB0CON_SEND
end
Receiver
goto start
org 0x002A
start
CLRF PORTA
MOVLW 0xff
MOVWF TRISA
MOVLW 0xff
MOVWF TRISC
CLRF PORTB
MOVLW 0xFB
MOVWF TRISB
movlw CIOCON_CONST
movwf CIOCON
movwf CANCON
check1:
bra check1
movlw BRGCON1_CONST
movwf BRGCON1
movlw BRGCON2_CONST
movwf BRGCON2
movlw BRGCON3_CONST
movwf BRGCON3
movlw START_CAN
;setup Rx Buffer
movwf RXB0CON
BRA Nomessage
MOVFF RXB0D0,var0
MOVFF RXB0D1,var1
MOVFF RXB0D2,var2
MOVFF RXB0D3,var3
MOVFF RXB0D4,var4
MOVFF RXB0D5,var5
MOVFF RXB0D6,var6
MOVFF RXB0D7,var7
BCF RXB0CON ,RXFUL
MOVFF var5,PORTA
MOVFF var6,PORTC
goto Nomessage
end
