lamic
Newbie level 1
ias - picojava II
Hi! I'm trying to building tests that are included with ias ( the simulation environment for picojava II core). I have done the following steps as explained in the documentation:
cd $PICOJAVAHOME/$PROJECT/sim/test/pico_vts
For each test suite under this directory, type:
gunzip <test-suite>tar.gz
or uncompress <test-suite>.tar.Z
Then type: tar -xvf <test-suite>.tar
type 'make' in every subdirectory under pico_vts
I have problem launching the make command. For example under the directory /basic, after the make command I obtain this output:
cd ./class; /cadtools/home/picojava/picoJava-II/sim/include/MakeTest `basename ../diag_pass.code .code` /cadtools/home/picojava/picoJava-II/sim/include/macro.inc /cadtools/home/picojava/picoJava-II/sim/test/pico_vts/basic/test_config.inc /cadtools/home/picojava/picoJava-II/sim/include/reset.code
Determining compilation instructions (macro.inc)...
Determining compilation instructions (test_config.inc)...
Determining compilation instructions (reset.code)...
Determining compilation instructions (diag_pass.code)...
Concatenating macro.inc, test_config.inc, and reset.code
Merging with diag_pass.code
Executing compilation instructions...
cpp -B -C -P -I$PICOJAVAHOME/picoJava-II/sim/include diag_pass
diag_pass.tmp:26: unterminated character constant
diag_pass.tmp:35: unterminated character constant
diag_pass.tmp:1782: unterminated character constant
diag_pass.tmp:1790: unterminated string or character constant
diag_pass.tmp:1795: unterminated string or character constant
diag_pass.tmp:1802: unterminated character constant
cpp: file path prefix `-C' never used
failed to run cpp -B -C -P -I$PICOJAVAHOME/picoJava-II/sim/include diag_pass.tmp > diag_pass.tmp2 at /cadtools/home/picojava/picoJava-II/sim/include/MakeTest line 99.
*** Error code 1
make: Fatal error: Command failed for target `class/diag_pass.class'
Has anybody ever used ias and can help me? Thank you very much.
*** Error code 1
