Help me fix combining ISE and XPS codes
j hemangini
Member level 1
I am using EDK9.2i and ISE9.2i. I made a project in EDK and then export it to ISE. When i opened this projet in ISE and compiled it i got the following error.
ERROR:LIT:411 - IOBUFDS symbol
"DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_s3_ddr2_phy.mpmc_phy_if_0/iobs/datapat
h_iobs/gen_dqs[1].dqs_iob/dqs_no_sim.diff_dqs.iobuf_dqs" (output
signal=DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_s3_ddr2_phy.mpmc_phy_if_0/dqs_in
t_delay_in<1>) does not have IOSTANDARD specified.
Errors found during logical drc.
Design Summary
Number of errors : 1
Number of warnings : 2
Process "Map" failed
Actually i have developed a simple code(VHDL) for LED on off controlled by switch using ISE and have configured the hardware using XPS . So now i want to add both of them . How can i do this.
And what is the problem for this error. Please tell me.
Thankyou.
j_andr
Full Member level 4
europe
xps in ise
j hemangini said:
ERROR:LIT:411 - IOBUFDS symbol/.../does not have IOSTANDARD specified
looks like you use an I/O cell or buffer but you did not tell the tool an I/O level
- 3.3V, 2.5, lvds, sstl etc.
add the information and should be ok;
j hemangini
Member level 1
add ise to xps
All component are defined like this in generated .vhd file of XPS project.
attribute BOX_TYPE of microblaze_0_wrapper : component is "black_box";
attribute BOX_TYPE of mb_plb_wrapper : component is "black_box";
attribute BOX_TYPE of ilmb_wrapper : component is "black_box";
attribute BOX_TYPE of dlmb_wrapper : component is "black_box";
attribute BOX_TYPE of dlmb_cntlr_wrapper : component is "black_box";
attribute BOX_TYPE of ilmb_cntlr_wrapper : component is "black_box";
attribute BOX_TYPE of lmb_bram_wrapper : component is "black_box";
attribute BOX_TYPE of rs232_dte_wrapper : component is "black_box";
attribute BOX_TYPE of leds_8bit_wrapper : component is "black_box";
attribute BOX_TYPE of dips_4bit_wrapper : component is "black_box";
attribute BOX_TYPE of btns_4bit_wrapper : component is "black_box";
attribute BOX_TYPE of spi_flash_wrapper : component is "black_box";
attribute BOX_TYPE of ddr2_sdram_wrapper : component is "black_box";
attribute BOX_TYPE of xps_bram_if_cntlr_1_wrapper : component is "black_box";
attribute BOX_TYPE of xps_bram_if_cntlr_1_bram_wrapper : component is "black_box";
attribute BOX_TYPE of xps_timer_1_wrapper : component is "black_box";
attribute BOX_TYPE of clock_generator_0_wrapper : component is "black_box";
attribute BOX_TYPE of debug_module_wrapper : component is "black_box";
attribute BOX_TYPE of proc_sys_reset_0_wrapper : component is "black_box";
attribute BOX_TYPE of xps_intc_0_wrapper : component is "black_box";
if i have to define the IOBUF here?
if yes then how and if no then where.
Plz suggest me.
