Help me find out why L298 gets so hot
tictac
Full Member level 5
Polland
Hi all
I make a circuit to control the rpm of a dc motor with L298 and atmega16.I use pwm for control the speed of the motor.L298 is getting hot at duty cycle below 40% but have a normal temprature at duty cycle 50% and higher .I use 4 diode shottky at to side of motor.
motor work at 500ma normally.
please help me.
by regards
hot l298
How did you connect the diodes? And what is the frequency that you drive PWM with?
I have design with single Mosfet and I can put on motors that "suck" 5 amps and FET doesn't even get warm.
transistor type used in l298
MOSFET does generate less heat when used in the switch mode.
Just Wonder: do you have any cap before the transistor? Somehow your transistor is not working in the switch mode.
l298 application note
I use 470uf cap on tow side of motor
Is it make the problem??
Added after 4 minutes:
hi bungee-
can you send me your h-bridge with mosfet,please??
l298 very hot
The cap probably is the reason putting the transistor on the low efficient amplify zone, which makes the device very hot.
why l298 get hot?
thank you.
I remove the cap.I also have a self (100uH)at the way of motor.is it make trouble?
Re: why l298 get hot?
I'm using IRF7455 and IRF7416 because you can drive them with logic level (5V).
I read a lot of Microchip application notes and I found them helpful.
Classic H bridge
Here are some links, that could be helpful:
https://ww1.microchip.com/downloads/en/AppNotes/00906B.pdf
https://ww1.microchip.com/downloads/en/DeviceDoc/41233C.pdf
Hope this help.
    tictac
tictac said:
thank you.
Is it a inductor filter?
why l298 get hot?
I use it for noise and make a slow change in current
why l298 get hot?
L298 could be damaged, 500mA is a very low current, it can support it without getting hot. Try to change it, measure the current of on the motor, maybe it is not 500mA.
why l298 get hot?
Check the load of the motor also, maybe it is too heavy that is why it sucks too much current.
    tictac
