Help me find division of two numbers in std_logic (VHDL)
vinodkumar
Full Member level 5
hyderabad
hi frns.need help to find division of two numbers in std_logic.iam very much thnkful if u help me.
manish12
Advanced Member level 3
Re: vhdl code
DIVISION IS IT A PART OF ONE OF THE OPERATION IN ALU ? OR IT IS JUST DISCRETE ONE INPUT A + INPUT B= > THEN PROCESSE => OUTPUT B .
white_shadow
Member level 1
Re: vhdl code
Well, the problem can be a pandora's box of sorts.
Here you have the problem of possibly having a remainder.
So you need to resolve a method of determining whether or not you have a remainder (modulo) or not. Then you need to store/concatenate your remainder.
Other than that you can do number conversions, for instance std_logic to integer and vice versa. This is actually a good practice for learning.
