asic1984
Full Member level 5
hi
i tried this example in proteus but it didnot work ,where is the problem
thanks for help
#include <p18f452.h>
#include <usart.h>
/* Set configuration bits for use with ICD2 / PICDEM2 PLUS Demo Board:
* - set HS oscillator
* - disable watchdog timer
* - disable low voltage programming
* - enable background debugging
#pragma config OSC = HS
#pragma config WDT = OFF
#pragma config LVP = OFF
#pragma config DEBUG = ON
void rx_handler (void);
#define BUF_SIZE 25
#pragma code rx_interrupt = 0x8
void rx_int (void)
_asm goto rx_handler _endasm
#pragma code
#pragma interrupt rx_handler
unsigned char c;
/* Get the character received from the USART */
c = ReadUSART();
if (c >= '0' && c <= '9')
// c -= '0';
/* Display value received on LEDs */
PORTB = c;
* Display the string located at the array offset
* of the character received
putsUSART (c);
PORTB = c;
else
* Invalid character received from USART.
* Display error string.
putsUSART (c);
PORTB = c;
/* Clear the interrupt flag */
PIR1bits.RCIF = 0;
void main (void)
/* Configure all PORTB pins for output */
TRISB = 0;
/* Open the USART configured as 8N1, 2400 baud, in polled mode */
OpenUSART (USART_TX_INT_OFF &
USART_RX_INT_ON &
USART_ASYNCH_MODE &
USART_EIGHT_BIT &
USART_CONT_RX &
USART_BRGH_LOW, 31);
/* Display a prompt to the USART */
putrsUSART ((const far rom char *)"\n\rEnter a digit 0-9!\n\r");
/* Enable interrupt priority */
RCONbits.IPEN = 1;
/* Make receive interrupt high priority */
IPR1bits.RCIP = 1;
/* Enable all high priority interrupts */
INTCONbits.GIEH = 1;
/* Loop forever */
while (1)
thanks for help
