Help me detect peaks and locations of them
Supaswing
Junior Member level 3
Imagine you have a signal like in the attachement (sorry, made with paint), noisy with not regular peaks and peak height at different levels. What you need is counting the peaks without missing them.
I most simple I thought was a low pass (smoothing) + discrimation (difference) + threshold + minima, but I am not satisfied with this.
What would do in that case?
Thank you
peaks detection
you need to do smothing .
then you need to take the difference of signal from its previous value after certain times.
When the difference goes from positive to negative you have found a peak.
Re: peaks detection
What if you pass this signal through a capacitor to remove dc and just count zero-crossings?
Regards,
IanP
Re: peaks detection
Like IanP suggested, you can couple with a cap and connect to a hi speed comparator with hysteresis then to a counter to count the peaks.
peaks detection
I suppose that some heurisitcs do apply for the case.
You can use floating threshold for matching as :
- smooth data with LPF (if digitally - choose some window to multiply)
- implement low and high peak detection by continuosly calculating derivative of smoothed data (positive to negative - high peak,
negative to positive - low peak). Update lowest peak for every case when it is observed.
- When high peak is detected compare it to the latest low peak observed plus constant threshold value .
Low pass filter frequency is dependent on shortest possible peak width or duration
Eliminating of DC part could lead to case some peaks will not pass zero and will be missed from recording .
Re: peaks detection
Thank you for your advices, the becuase trouble comes from the threshold or the hystersis setting, which I want to be autoadjusted, and actually there is a lot of divergence from sample to sample and some min are higher than other max even after high passing.
And furthermore I would like to determine the location of the peaks.
Any idea?
Thank you very much
peaks detection
I already suggested floating threshold . Look to pseudocode for explanation
input signal f(t)
smoothed signal lp(t) (filtered windowed)
get_sample() - returns lp(t)
report_peak() - it is called upon peak detection
sign = 0;			// sign of derivation lp(t) - lp(t-1)
prev = 0;			// lp(t-1)
current = 0;			// lp(t)
CONST;				// constant value to be added to floating threshold base
bottom;				// floating threshold base
prev = get_sample();
current = get_sample();
sign = current >= prev? 1: -1;
if(sign == 1)
	bottom = prev;
for(;;)
	prev = current;
	if(sign == -1)
		if(current >= prev)
			sign = 1;
			bottom = prev;
	else
		if(current < prev)
			sign = -1;
			if((bottom + CONST) < prev)
				report_peak();
