Help me design an audio amplifier with 20W output using BJT and opamp
harikrishnam
Junior Member level 3
i want to design audio amp with 20w output using bjt and opamp if any body knows plz try to help me.sorry for my bad English.if possible mention theoretical calculation also
thanks in advance.
Re: audioamp design help
There is lots and lots and lots and lots and lots and lots and lots and lots and lots of information about this on the web. Look at manufacturers websites; do a search of audio amplifiers, etc., Your question is too general to give a valid answer here.
There's no need to apologise for not having a perfect command of English. Many members of the forum are not native speakers either. As long as you can make yourself understood, it's OK. However, please avoid SMS style of writing like "plz" and bad punctuation.
Designing a proper audio amplifier from scratch is an advanced process. If you just want to build one, you can find plenty of existing designs on the net. If you want to learn how to design it, the process is quite complex and requires knowledge of many fundamental principles. It may be better if you read books and online references first and then ask specific questions in a forum.
