Help me design a mod n bit counter
balan
Member level 2
hi guys,
i need to design a mod n bit counter for my project. how to reset the counter when the desired count. help me.
thank you
madhavisai
Member level 2
mod n counter
use T ff use defined primitve and write the code for asynchronous counter
balan
Member level 2
Re: mod n counter
hi,
thank you,
but u have a implemented in other logic,
define parameter modcount =N;
while counting use the code as count = (count+1) % modcount;
which will reset the counter to reset value when desired count is achieved.
try this.
thank you.
