Help me design a 80dB opamp with 10uF capacitance load
Re: A OPAMP design
where can i get that texas manual?? any link
Re: A OPAMP design
With such a big Cload you can use 2 stage amplifier without compensation
A OPAMP design
Without specify which technology you will use, it's kind of hard to suggest the topology.
A OPAMP design
ya folded casoce may work for the specification
Re: A OPAMP design
using self-compensation
Re: A OPAMP design
Anyway you need a strong output buffer stage to reduce your output resisitance a lot.
I think you may need 3 stages: one input stage, one amplification stage and one output buffer stage.
Re: A OPAMP design
you can use some other configuration
Re: A OPAMP design
The classic solution is to put a resistor in series with your load capacitor. Then at high frequencies the opamp load looks like a resistor. For example iof you place a 1kohm in series with your 10uf load the result at high frequencies will look like you are driving a 1kohm load. Of course it will take time to charge up the output.
A OPAMP design
Class AB+Floaded-casecode is ok
It can push-pull high couple cap in audio application
A OPAMP design
folded cascode opamp can solve this problem.
Re: A OPAMP design
Have you tried symetrical amplifier with OTA output?
A OPAMP design
As Montage3000 told you : "put your main pole at the output "
it means the most suitable amplifier for your requierement (as I saw actually) is a OTA.
Re: A OPAMP design
what is the app.
A OPAMP design
I think folded cascode is very difficult to control Rout. We can use normal two-stage with high W/L in differential pair and choose suitable bias current.
Re: A OPAMP design
Folded cascode with gain boost auxiliary will be good enough for these specs.
A OPAMP design
gain boost+fold cascode
regards
Re: A OPAMP design
so large load,it a hard job
A OPAMP design
Two-stage opamp is not suitable for this application.
Folded cascode OTA or with gain boost is your better choice.
