Help me convert C code to hex code
intan
Member level 2
hi!
can somebody help me to convert this code to hex code?
i m using pic 16f876a and hitech c language
i hv tried many times but still cant work
thanks in advance
sau_sol
Full Member level 5
India
short and long hex codes
where is the code ??????
intan
Member level 2
lcd_goto(20)
here is the code
#include<pic.h>
//===============configuration==============================
__CONFIG (0x3F32);
//===============define IO port=============================
#define lcd PORTC
#define RS RA2
#define E RA5
#define CHANNEL0 0b10000001 // AN0
#define CHANNEL1 0b10001001 // AN1
#define buzzer RB5
#define fanA RB4
#define fanB RB3
#define ledA RB2
#define ledB RB1
//==============FUNCTION PTOTOTYPE=========================
void e_pulse(void);
void delay(unsigned short i);
void send_char(unsigned char data);
void send_config(unsigned char data);
void lcd_goto(unsigned char data);
void lcd_clr(void);
void dis_num(unsigned long data);
void increment(unsigned long data);
void read_adc(void);
unsigned short read_temp(void);
//====================MAIN================================
unsigned short result;
unsigned short temp,tempA,tempB;
void main(void)
ADRESH=0; //clear A/D result
ADRESL=0; //clear A/D result
//setting ADCON1 Register
ADCON1=0b11000101; // A/D result right justified,
// configure RA2 and RA5 as digital I/O
TRISA=0b11011011; //configure PORTA I/O direction
TRISB=0b00000000; //configure PORTB as output
TRISC=0b00000000; //configure PORTC as output
PORTA=0;
PORTB=0;
while(1)
send_config(0b00000001); //clear display at lcd
send_config(0b00000010); //Lcd Return to home
send_config(0b00000110); //entry mode-cursor increase 1
send_config(0b00001100); //diplay on, cursor off and cursor blink off
send_config(0b00111000); //function set
lcd_goto(0); //cursor start from beginning
//display character on LCD
send_char(' ');
send_char('T');
send_char('E');
send_char('M');
send_char('P');
send_char('.');
send_char('A');
send_char('=');
lcd_goto(20); //cursor go to 2nd line of the LCD
send_char(' ');
send_char('T');
send_char('E');
send_char('M');
send_char('P');
send_char('.');
send_char('B');
send_char('=');
while(1) //infinity loop
//sensor A
ADCON0=CHANNEL0; //CHANNEL1=0b10001001
lcd_goto(8);
read_adc();
temp=read_temp();
dis_num(temp/10);
send_char('.');
dis_num(temp%10);
send_char(0b11011111);
send_char('C');
send_char(' ');
send_char(' ');
tempA=temp;
//sensor B
ADCON0=CHANNEL1; //CHANNEL0=0b10000001
lcd_goto(28);
read_adc();
temp=read_temp();
dis_num(temp/10);
send_char('.');
dis_num(temp%10);
send_char('C');
send_char(' ');
send_char(' ');
tempB=temp;
if((tempA>500)&&(tempB<500)) // *****************************************
{ // * LED A and Fan A activated only for *
ledA=1; // * temperature A greater than 50'C *
ledB=0; // * and temperature B less than 50'C *
fanA=1; // *****************************************
fanB=0;
buzzer=0;
else if((tempB>500)&&(tempA<500)) // *****************************************
{ // * LED B and Fan B activated only for *
ledA=0; // * temperature A less than 50'C and *
ledB=1; // * temperature B greater than 50'C *
fanA=0; // *****************************************
fanB=1;
buzzer=0;
else if((tempB>500)&&(tempA>500)) // *****************************************************
{ // * All LED A & LED B, Fan A & Fan B and Buzzer *
ledB=1; // * activated for temperature A greater than 50'C *
ledA=1; // * and temperature B greater than 50'C *
fanA=1; // *****************************************************
fanB=1;
buzzer=1;
else if((tempB<500)&&(tempA<500)) // *****************************************************
ledB=0; // * disactivated for temperature A less than 50'C *
ledA=0; // * and temperature B less than 50'C *
fanA=0; // *****************************************************
fanB=0;
buzzer=0;
delay(2000);
//==================subroutine LCD setting ==========================
RS=0;
lcd=data;
delay(500);
e_pulse();
void e_pulse(void)
E=1;
delay(500);
E=0;
delay(500);
RS=1;
lcd=data;
delay(500);
e_pulse();
if(data<16)
send_config(0x80+data);
else
data=data-20;
send_config(0xc0+data);
void lcd_clr(void)
RS=0;
send_config(0x01);
delay(600);
unsigned char hundred_thousand;
unsigned char ten_thousand;
unsigned char thousand;
unsigned char hundred;
unsigned char tenth;
hundred_thousand = data/100000;
data = data % 100000;
ten_thousand = data/10000;
data = data % 10000;
thousand = data / 1000;
data = data % 1000;
hundred = data / 100;
data = data % 100;
tenth = data / 10;
data = data % 10;
if(hundred_thousand>0)
send_char(hundred_thousand + 0x30); //0x30 added to become ASCII code
send_char(ten_thousand + 0x30);
send_char(thousand + 0x30);
send_char(hundred + 0x30);
send_char(tenth + 0x30);
send_char(data + 0x30);
else if(ten_thousand>0)
send_char(ten_thousand + 0x30); //0x30 added to become ASCII code
else if(thousand>0)
send_char(thousand + 0x30); //0x30 added to become ASCII code
else if(hundred>0)
send_char(hundred + 0x30); //0x30 added to become ASCII code
else if(tenth>0)
send_char(tenth + 0x30); //0x30 added to become ASCII code
else send_char(data + 0x30); //0x30 added to become ASCII code
unsigned short j;
for(j=10;j>0;j--)
{ lcd_goto(32);
data=data+1;
dis_num(data);
delay(10000);
//==================subroutine ADC=========================
void read_adc(void)
unsigned short i;
unsigned long result_temp=0;
for(i=2000;i>0;i-=1) //looping 2000 times for getting average value
ADGO = 1; //ADGO is the bit 2 of the ADCON0 register
while(ADGO==1); //ADC start, ADGO=0 after finish ADC progress
result=ADRESH;
result=result<<8; //shift to left for 8 bit
result=result|ADRESL; //10 bit result from ADC
result_temp+=result;
result = result_temp/2000; //getting average value
unsigned short temp;
temp=result;
return temp;
//==================subroutine DELAY==========================
for(;i>0;i--);
yus
Member level 2
Philippines
lcd_goto(20)
#include<pic.h>
__CONFIG (0x3F32);
#define lcd PORTC
#define RS RA2
#define E RA5
#define buzzer RB5
#define fanA RB4
#define fanB RB3
#define ledA RB2
#define ledB RB1
void e_pulse(void);
void lcd_clr(void);
void main(void)
PORTA=0;
PORTB=0;
while(1)
send_char(' ');
send_char('T');
send_char('E');
send_char('M');
send_char('P');
send_char('.');
send_char('A');
send_char('=');
send_char(' ');
send_char('T');
send_char('E');
send_char('M');
send_char('P');
send_char('.');
send_char('B');
send_char('=');
//sensor A
lcd_goto(8);
read_adc();
temp=read_temp();
dis_num(temp/10);
send_char('.');
dis_num(temp%10);
send_char('C');
send_char(' ');
send_char(' ');
tempA=temp;
//sensor B
lcd_goto(28);
read_adc();
temp=read_temp();
dis_num(temp/10);
send_char('.');
dis_num(temp%10);
send_char('C');
send_char(' ');
send_char(' ');
tempB=temp;
fanB=0;
buzzer=0;
fanB=1;
buzzer=0;
fanB=1;
buzzer=1;
fanB=0;
buzzer=0;
delay(2000);
RS=0;
lcd=data;
delay(500);
e_pulse();
void e_pulse(void)
E=1;
delay(500);
E=0;
delay(500);
RS=1;
lcd=data;
delay(500);
e_pulse();
if(data<16)
else
data=data-20;
void lcd_clr(void)
RS=0;
send_config(0x01);
delay(600);
data = data % 1000;
data = data % 100;
tenth = data / 10;
data = data % 10;
else if(thousand>0)
else if(hundred>0)
else if(tenth>0)
unsigned short j;
for(j=10;j>0;j--)
{ lcd_goto(32);
data=data+1;
dis_num(data);
delay(10000);
void read_adc(void)
unsigned short i;
result=ADRESH;
temp=result;
return temp;
for(;i>0;i--);
attached below is the generated hex using Hi-Tech PICC PRO 9.6 PL4.
(using pic16f876a mcu)
intan
Member level 2
hex code for hindi
nothing wrong with the code rite?
then how about this circuit? anything wrong?
why it cant work?
and if i want to remove the voltage regulator, is it ok?
i want to redraw the circuit, what software should i use? any suggestion?
thanks
intan
Member level 2
hex code for led
btw how can i knw the memory has been used?
yus
Member level 2
Philippines
#600 hexcode
there's no errors (and warnings) during the compilation of the code..
but it's not an assurance that there nothing wrong with the code.
you can use Proteus to redraw the circuit, and also to simulate it as well..
intan
Member level 2
500 = 0x30
can gv me a link to download proteus?
