Help me control simple IDA controller hard disk over USB
azhar_multan
Newbie level 3
cy7c68013
I want to control simple IDA controller hard disk over USB. Wishing to use FTDI chip FT245BM. Can any one please guide me on this topic.
Moved here /Cluricaun
Hard disk Over USB
HI,
You send your message in the wrong forum.
You should send it to Professional Hardware and Electronics Design or Microcontroller forums.
SphinX
Hard disk Over USB
yes,please look here , it's a simple prj get data from IDE .
You can port it to avr chip, or other chip.
h**p://w*w.pjrc.com/tech/8051/ide/
Re: Hard disk Over USB
works well, ISD-300A1 from cypress.
h**p://www.cypress.com/products/datasheet.cfm?partnum=ISD-300A1
Hard disk Over USB
It's cheaper to buy a simple USB2.0 mobile rack
for 2.5" HDD, and use it, won't worth to build one
if you just want an USB to IDE converter. (15-20 EUR)
I used one to my MP3 project as they did on https://www.pjrc.com, had to isolate the Vpp and Gnd of the HDD, and it's working.
Zed
By all accounts the FTDI chip is fairly popular and there seems to be a lot of information floating around in these forums. I personally used philips isp1581, this also seems to be a popular chip and there are support out there for it. Its another chip to consider.
Hey look this article....this circuit looks to work...the article is in Polish but you can get the idea with a traslator. the circuit is based on the IC CY7C68013
TUSB6250 by **broken link removed**
