Help me connect a BT module to Pic16F877a and use it for sending data
gold12star
Junior Member level 3
BT Module Pic16F877a
hello
I reach the end steps in my project and I face problem which is I conneced the BT module (Wireless Bluetooth TTL Transceiver Module [RF-BT0417C] - $9.95 : MDFLY electronics, Your electronics supplier!) with uController (tx to rx and vie versa) then I can found the BT on my mobile but I cannot connect to it.I think I should connect CTS and RTS to something but I don't know what (see the code that I think the connection should be for CTS and RTS but I'm not sure about that ).
So Any one can recommended me to how can I send data from mobile to uController through BT module ?? ( MikroC code what I want to help me in and not the mobile program until now I check the connection by sending photo from my phone)
the MikroC code is the following:
unsigned short i;
void main() {
  TRISD = 0b00000100;    //           CTS as input & RTS as output
  PORTD = 0b00001000;
  UART1_Init(115200);               // Initialize UART module at 115200 bps
  Delay_ms(100);
   while (1){
    if (UART1_Data_Ready()) {      // If data is received
      i = UART1_Read();         // Read the received data
      //UART1_Write(i);           // Send data via USART
      TRISB = 0b00000000;
      PORTB = 0b10000000;       // led
I am waitting for help
replay to me as soon as possible
thank you
Re: BT Module Pic16F877a
60 view and no one reply. whyyyyyyyyy???:cry:
Do you expect to receive every bluetooth module n the World?
You have to write configuration to the Bluetooth module and negotiate the connection before you can transfer data.
Brian.
thank you
but how can I write the configuration to the Bluetooth module in MikroC??
please help me
The data sheet from the web site you gave is useless!
I suggest you look at the part number on the CSR IC and contact the manufacturer for more information they are at **broken link removed**
Use "UARTx_Write_Text()" to send AT commands to the module in MikroC and "UARTx_Read_Text()" to read the response.
Brian.
thank you i will try what you suggest
Let me know if you are able to get any support from CSR.
I did a consulting job for a company where we used a CSR chip. They refused to give me any support without me purchasing a kit for 3000 USD!
I try to search the same bluetooth module but I don't found in CSR
so I don't contact with CSR
CSR Didn't make the module, they made the bluetooth chip on the module.
ok
thank you
I wiil try to contact
I think I can connect with bluetooth but there is very long delay between sending date and recieving action from Pic16f877a
any one know the cause of that??
I need some help that may support me
