Help me configure Internet connection on Fedora 5
venkat3271
Full Member level 2
Chennai
Hey,
I have installed Fedora 5... I cant able to configure my net connection in fedora.. I am having DSL modem connected to my Ethernet card... Where i want to configure.???. When i searched in net , i got a software called "rp-pppoe-3.8", which when i installed ,asked all the details such as user name , pass word, DNS address etc(AND IT CHANGES pppoe.config FILE in /etc ACCORDINGLY)... But still , after this software says "connected!! ", i cant able to browse
.. Pl help me ....
Thanks in advance,
Venkatesan.s
Re: Net connection???
PPPoE (Point-to-Point Protocol over Ethernet) is a protocol used by many ADSL Internet Service Providers. Roaring Penguin has a free PPPoE client for Linux and Solaris systems to connect to PPPoE service providers.
Dubbed RP-PPPoE, this open-source product is ideal for Linux users with a DSL "modem" whose Internet service provider uses PPPoE. Before you download this software, check whether or not you really need it.
rp-pppoe your ISP uses PPPoE, but has given you a router, you may not need a PPPoE client on your Linux box. DHCP may work fine.
Net connection???
rp-pppoe-3.8 have a gui interface, you can use it to watch status of the net.
Maybe your firewall's security is high that reject all the package.
Ryan
    venkat3271
Ryan
Hey,
I disabled the firewall and tried using rp-pppoe-3.8.. but Still i cant connect to net
When i use "pppoe-status" , i shows my IP address but the transmitted and recieved bytes is showing as "TX: 3:Error RX:3 Error "... IS there any other software which sort out this problem?????
Net connection???
1. I have used a command line type of pppoe software.
adsl-setup, adsl-connect, adsl-statue.you can try them.
adsl-setup give you steps to config you ISP.
adsl-connect begin to connect to net. if the response say ok, then maybe you can connect ot net.
2. Check if your ethernet network card is fine.
    venkat3271
Thanks RDRyan......... I got connection in fedora... I used that adsl-setup command to configure it..
Thanks a lot....
