djalli
Advanced Member level 3
dsp-filter
I need you advice in choosing a precise DSP filter.
I need an DSP chip. IC.
I like to use it this filter as notch Filter to block certain frequency range but not limited of being flexible as an application may want.
Frequency range to block is 0.5Hz to 2Hz, or 0.5-1Hz.
The signal passing this filter will be a sinusiod from 0.1Hz to 10Hz. Before filtering singal will be sampled at 1Khz and quantized at 12bits.
Which, how much will cost, what I shoukd change in terms of sampling quantization?
Please do advice me.
Many thanks,
djalli
Many thanks,
djalli
